🎉Community Raffle - Win $25
Join and Win
CADFEKO openGL not fuonded
User: "Giovanni_barreca"
Altair Community Member
Hi, I installed FEKO for the first time on my pc, that is not too old with ryzen 9 and 6700s, but when I first tried to start CADFEKO the error in the image appeared.
I have the latest driver on my Pc and the others program in the suit work like a champ. Someone else have had my same problem?
1 - 6 of 61
    User: "Zeina"
    Altair Employee
    Accepted Answer
    Updated by Zeina
    Hi @Giovanni_barreca
    You can check the OpenGL version you have by:
    1- Download and install the OpenGL viewer (https://www.realtech-vr.com/home/?page_id=142)
    2- Run it on your machine, you will be able to see something similar to the following:
    With this you can check if your OpenGL version is = > 3.3
    Best Regards,
    Zeina
    OP
    So I checked with the program you prompt me and my system has OpenGL 4.6 version but I still have the same error message. I also tried by uninstalling and reinstalling the driver but it didn’t have work
    User: "Shannon_Mistry"
    Altair Employee
    Updated by Shannon_Mistry
    Hi @Giovanni_barreca ,
    It is recommended to update the drivers to the most recent patch. Please update and see if that helps.
    Regards,
    Shannon
    OP
    Hi, thanks for yours answer. I'm pretty sure to have the last version of drivers for my gpu installed.
    Here is a print of all the information from openGL viewer. Tell me if sharing others detail you can help me.
    OP
    I have more news about my problem, I think that my installation have problem fuonding some dll of openGL in my path
    Launching: CADFEKO 2024.1 : 8646
    CRITICAL: Failed to load libEGL (Impossibile trovare il modulo specificato.)
    Warning: QWindowsEGLStaticContext::create: Failed to load and resolve libEGL functions
    Warning: QOpenGLWidget: Failed to create context
    I tried installing a older version of FEKO and that is the log that, with the help of chatgpt I found
    User: "Zeina"
    Altair Employee
    @Giovanni_barreca ,
    Glad the issue is resolved on your side.
