Saving videos from EDEM simulations
Reem_Kh
Reem_Kh Altair Community Member
Dear EDEM users,
If I have already done several simulations on EDEM, does somebody know an automatic way to access the simulations and save the videos? Without manually entering each simulation file and saving it…
Thanks a lot.
Answers
  • GTT Adam
    GTT Adam
    Altair Employee
    Hi @Reem_Kh,
    You can script the import of animation files and the subsequent export of a GIF/MP4 in HyperView using TCL commands.
    You can view your completed commands in HyperGraph using the HWC window (View » HWC Console) and use the recorded steps to create your TCL script.
    Scripts can then be imported into HyperView using the File » Load » Script
    Hope this helps!
    Adam Reid
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi,
    You can export images during run time, but not videos:
    Site faviconExport images during run-time
    This is designed more for a continual visualisation of what is happening during the simulation as it doesn't include the attribute colouring, but you could then turn the exported images into a video.
    Regards
    Stephen
Welcome!
Welcome!
