To enable/disable viewing an animation from within Inspire, you just need to toggle on/off the Review Motion Analysis icon. There is an animation to view within Inspire if we see a blue check mark:
The check mark will disappear if you have modified the model from the previously simulated state.
It is recommended that you also generate an animation file by default by choosing "Include all data" for "Generate Animation File" in the run options:
This way, animations (H3D) can be loaded into HyperView from the run folder if you accidentally modified the model and still want to see the previous animation.
Hi Azola,
Hope this helps!
Adam Reid
