🎉Community Raffle - Win $25
Join and Win
Is it possible to work around the 1 load/surface/load case limitation in Inspire and SimSolid?
User: "Lapinaute"
Altair Community Member
The analyses I would be running require to have several loads applied to one surface in a single load case. Inspire (2024) and SimSolid (2024) both fail to run an analysis if more than a single load is applied to the same surface (see image below)
. Does anyone know how to work around that problem? Thanks!
