CADFEKO openGL not fuonded
Hi, I installed FEKO for the first time on my pc, that is not too old with ryzen 9 and 6700s, but when I first tried to start CADFEKO the error in the image appeared.
I have the latest driver on my Pc and the others program in the suit work like a champ. Someone else have had my same problem?
Hi @Giovanni_barreca ,
It is recommended to update the drivers to the most recent patch. Please update and see if that helps.
Regards,
Shannon
I have more news about my problem, I think that my installation have problem fuonding some dll of openGL in my path
Launching: CADFEKO 2024.1 : 8646
CRITICAL: Failed to load libEGL (Impossibile trovare il modulo specificato.)
Warning: QWindowsEGLStaticContext::create: Failed to load and resolve libEGL functions
Warning: QOpenGLWidget: Failed to create context
I tried installing a older version of FEKO and that is the log that, with the help of chatgpt I found
You can check the OpenGL version you have by:
1- Download and install the OpenGL viewer (https://www.realtech-vr.com/home/?page_id=142)
2- Run it on your machine, you will be able to see something similar to the following:
With this you can check if your OpenGL version is = > 3.3
Best Regards,
Zeina
Best Regards,
Zeina
