How do we find out which area is under tension and which area is under compression during a static stress stress result analysis?
Aditya Hegde_22173
Aditya Hegde_22173 Altair Community Member
edited May 2024 in Community Q&A
I have done a static stress analysis and got the result for maximum stress distribution area, I wanted to which area undergoes compressive stress and which area is under tensile stress, what are the options in the hyperview to visualize that?
Answers
  • Fabio_Barsotti
    Fabio_Barsotti Altair Community Member
    You should see the diagonal of the principal stress tensor, under Max Principal and Min Principal.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    hi,
    additionally, i'd suggest you to load your results into HyperView and contour Signed vonMises.
    It shows you in a single result what regions would be in tension and whatregionsunder compression.
    the below example is a simply supported beam, tension in the bottom and compression at top.
Welcome!
Welcome!
