Temperature Load Visualization
Vladimir_Gantovnik
Vladimir_Gantovnik Altair Community Member
Guys, how to make contours plots of temperature (not results in HyperView, but applied thermal loads in HyperMesh)? I have TEMPERATURE(LOAD) and TEMPD cards in my Nastran deck. I know how to do it in Patran Loads/BCs/ Plot Contours/Temperature/. Then select Load case, Select existing Set: temp.### Select Data Variable: Temperature.
Thank you!
Welcome!
Best Answers
  • Gunter
    Gunter
    Altair Employee
    Answer ✓
    Hello Vladimir,
    Can you please try Contour Loads from the Analysis Ribbon?
    Best regards,
    Gunter
  • Gunter
    Gunter
    Altair Employee
    Answer ✓
    Hello Vladimir,
    Thanks for the reply.
    Unfortunately we can't select elements based on this contour plot.
    As a workaround one can save the the contour into a *.res file.
    And use this result in HyperView, to select entitites by contour and create a set.
    This set can be exported to HyperMesh.
    Best regards,
    Gunter
Answers
  • Gunter
    Gunter
    Altair Employee
    Answer ✓
    Hello Vladimir,
    Best regards,
    Gunter
  • Vladimir_Gantovnik
    Thank you, Gunter! It works! Very nice. Thank you for the video. I actually tried to use Contour Loads tool, but I did not click Contour button, and. of course, did not get results. In Patran using this Temperature Contour Plots and List Tool we can select elements based on current fringe value, for example, make list of elements with T>500F. Is it possible to make set of elements with T>500F from the temperature map?
  • Gunter
    Gunter
    Altair Employee
    Answer ✓
    Hello Vladimir,
    Best regards,
    Gunter
Welcome!
Welcome!
