Guys, how to make contours plots of temperature (not results in HyperView, but applied thermal loads in HyperMesh)? I have TEMPERATURE(LOAD) and TEMPD cards in my Nastran deck. I know how to do it in Patran Loads/BCs/ Plot Contours/Temperature/. Then select Load case, Select existing Set: temp.### Select Data Variable: Temperature.
Thank you!
