Hey why can't this model be downloaded?
EDEM CUDA API - Contact Model Example: Hertz-Mindlin Effective Sphere
Overview
Attached is the source code for the Hertz-Mindlin Effective Sphere model using version 3.3 of the API. Please note that this has been written for EDEM’s CUDA solver and as such will only run on Nvidia GPUs. The model is for the base contact model only; for rolling friction please add a rolling friction model from the EDEM GUI.
The source code consists of:
Two .cpp files
- CHertzMindlinEffectiveSphere_v3_3_0.cpp
- HertzMindlinEffectiveSphere_v3_3_0.cpp
One .h file
- CHertzMindlinEffectiveSphere_v3_3_0.h
One .cu file
- HertzMindlinEffectiveSphere_v3_3_0.cu
To use the model, the CPU-API code should be compiled into a library file. When running a simulation the .cu file should be in the same location as the library file.
Please see the EDEM API Documentation and the Programming Guide > GPU API User Guide in the EDEM help for further details.
Usage/Installation Instructions
0 -
Sounds good thank you.
0 -
I am defining custom properties in the CUDA file.
I have found a way to define the custom property based on what i saw here
Please let me know how this can be connected to the debugger, similar to what we see in the snooker factory. I have not seen a single example that shows how to debug the cuda file. Please tell me where should i connect the CUDA file in VS?
(I am not able to delete the comment. I found the solution there is a CUDA tutorial )
0 -
Hi, I don't know of any way to incldue the CUDA file in visual studio debugger however you can include printf in the CUDA code to write out values (doubles and integers) to a command window. You can then place the printf fuctions in differnet areas of the code to ssee what values are been assigned.
To use:
Open a command window and start EDEM with the flag —no-free
edem --no-free
And in your .cu code you can include have lines such as:
real3 test1 = F_total_n; printf("test1.x = %f \n", test1.x ); printf("test1.y = %f \n", test1.y ); printf("test1.z = %f \n", test1.z );
Then this will print out the results into the command window.
Note that printf is a slow function so make sure you remove it once you've finished debugging to avoid slowing down the simulation.
RegardsStephen
0
