Stress-strain curve during the calendering of and electrode
aloktiwari
aloktiwari Altair Community Member
Hey
I am simulating the compression of polydisperse particle system in 3D box, where gravity normal direction is periodic. Compressing the plate first for 20 ms and then moving the plate up so electrode can relax.
I am looking at obtaining the stress-strain curve for that, strain for me is the thickness of the electrode.
A bit confused about the calculation of stress -
  2. Compressive force on all the particles
  3. Interparticle force while particles are in contact( summing up normal and tangential force obtained from contact → normal/tangential force
I am looking for the stress-strain plot from which I can distinguish between the elastic and plastic regime and get the idea of Young's modulus. If anyone is having any idea, please share.
Best Answer
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Hi, the stress should be the (Total Force on the compressing plate in direction of motion) / surface area of the electrode. You could query Total Contact Normal Force between the material and the compressing plate which would give the same result, and you could also then differentiate between any
    Compressive force is the sum of the contact normal forces, total compressive force should be similar in this instance however it doesn't take direction into account so best not to use in a case like this..
    Regards
    Stephen
Answers
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Regards
    Stephen
  • aloktiwari
    Hey Stephen,
    Thank you for your suggestion!
    I tried the same approach and observed similar behavior when plotting the pressure on the wall due to particles. In this case, the results are comparable, but they may differ in other scenarios.
    I appreciate your input on determining pressure based on the force component along the line of motion.
    Thanks again!
Welcome!
Welcome!
