🎉Community Raffle - Win $25
Join and Win
nonlinear static structural analysis. Apply increasing load in steps & release.
User: "David_R"
Altair Community Member
Updated by David_R
Using Optistruct & Hypermesh non linear static analysis, I wish to apply increasing load in steps and then release the load. I wish to see the residual deformation due to yielding of the structural steel once the applied load has been removed.
This is not a transient time dependent scenario. I believe DLOAD, TLOAD1, TABLED1 cards may be relevant.
1 - How are Optistruct users best able to learn this loading method?
2 - where in the support documentation is this covered? This is a fundamental FEA topic.
1 - 4 of 41
    you can perform NL Static Simulation in OptiStruct, for this.
    There are 2 ways:
    • multiple NL Static loadcases with each loadcase final load value as desired (using CNTNLSUB option to create subsequent loadcases)
    • single NL Static loadcase, using TLOAD1 and TABLED1 to create a pseudo-time table, with the carying load, as you've supplied in the table above.
    For option #1, I would just run 1st loadcase from zero to point 5, and then 2nd loadcase from 5 to 7, and last subcase removing all load.
    User: "ginger no"
    Sir,
    Hello,
    I've recently encountered a similar issue and tried the following method:
    In the load card (e.g., a Force card), I selected 'curve' and 'vector' as the type. Then, at the location circled in red in the attached image, I selected a TABLED1 type curve to define the load magnitude vs. time curve.
    However, looking at the results, it seems the load was not applied according to the curve but was instead calculated based on the NINT increments on the NLPARM card.
    I would like to ask: is this method fundamentally incorrect, or is there likely a mistake in my settings?
    Any help would be appreciated.
    User: "David_R"
    OP
    Updated by David_R
    Thanks.
    It was the CNTNLSUB option that I was not aware of & needed to add to my assumed method. This method then has the advantage that it allows different NLPARM, NLOUT, NLAPADT cards for each case.
    correct. For multiple loadcases, you're allowed to use different setup. You could also try the newer NLCTRL which replaces most of these into a single card. There was an error displaying this embed.
    i've found these around here… 1 example using 2 loadcases, and another with a single subcase, "time" dependent.
