oka wear calculations have poor repeatability
When using the OKA model for GPU-based wear calculations in EDEM, the wear depth results are inconsistent when calculating the same model twice. However, the results are consistent when using the Archard model.
This is the first calculation
I just roll back the time step to the beginning and click on start the second run.
Obviously the second calculation is larger than the first, with an error of 5.5%. Sometimes it is smaller than the first.😓
Hi,
In addition to Stephen Cole comments, I want to add another point i.e
the another reason for difference of wear in 2 simulation are the way particles created and rotated the drum i.e if you create material and rotate the drum as a sequence of operation then there is a possibility of difference is due to factory settings( random generation creates particles each time at different position and orientation which may lead small difference in results) However the error in your simulation is in 6th or 7th decimal and it might be negligible I feel.
Thanks,
Prasad A
Hi,
It looks like the mesh is quite coarse, I'd recommend making the geometry mesh about the same size as the particles if looking at wear. I'd also make sure you are using the default settings in the simulator Advanced Settings, also recommend using Double Precision to test if that makes a difference.
Regards
Stephen
Hi,
Thanks,
Prasad A
Hi,
Regards
Stephen
