When using the OKA model for GPU-based wear calculations in EDEM, the wear depth results are inconsistent when calculating the same model twice. However, the results are consistent when using the Archard model.
This is the first calculation
I just roll back the time step to the beginning and click on start the second run.
Obviously the second calculation is larger than the first, with an error of 5.5%. Sometimes it is smaller than the first.😓
