🎉Community Raffle - Win $25
Join and Win
Mesh problem with physics lines
User: "sw07"
Altair Community Member
Hello.
After meshing, I checked physics and got the following message.
  • message
Begin of physical check ...
The lines :
of the plan of periodicity have no linked discretisation.
The mesh periodicity is not assured.
The PERIODICITY PeriodicityNumberZaxis can not be taken into account Lines of the constraint without reference line:
25 235
To obtain the same line mesh on lines, you may use a LINKED MESH_LINE End of physical check.
checkPhysic executed
The lines :
25 28 235 243 248 252 255 258 262 263 of the plan of periodicity have no linked discretisation.
I wonder how to solve it.
Please reply.
Thank you.
1 - 1 of 11
    Hi,
    You can resolve it in three ways :
    1. Check under Mesh lines, if you have Infinite_Box_mesh_generator is already created or not. If yes, assign it to the lines that are shown in the error.
    2. If not, Create a new mesh line as in the picture below. This represents linked mesh line based on your periodicity. Then assign this mesh line to lines in error. image.png
    3. Delete mesh < Delete Infinite box and recreate the infinte box and complete it. This will by default create the infinite box mesh line and assign it to border lines.
    Thank you,
    Lavanya
