Distortion of the section after trimming
sbhbajra
sbhbajra Altair Community Member
edited January 30 in Community Q&A
I am trying to model a K Joint. I used surface line to cut a section in the chord thickness through the weld brace and weld width. I used solid edit,, trim with lines, with sweep lines and use Y axis for the direction. But after the trim I get distorted section as shown in Fig 2. What could be the possible cause of this
Figure 1: Quarter section of K joint
Figure 2 using with sweeping lines
Fig 3 : the distorted section where i cannot do meshing
can anyone please help me to resolve this issue
Welcome!
Answers
  • Gunter
    Gunter
    Altair Employee
    Hello sbhbajra,
    It's hard to explain from the pictures.
    Can you upload the model?
    What HyperMesh version are you using?
    Best regards,
    Gunter
  • sbhbajra
    I have uploaded the model. I have used hypermesh 21. If you could see in the model, i have been experiencing additional problems, the distortion of meshing in the brace
    I would be grateful if you could help me
  • Gunter
    Gunter
    Altair Employee
    I would recommend to remove the cuts at the opposite side of the tube.
    This can be done via Boolean operation combine.
    It's also a geomtry visualization issue.
    Hide the geometry and you will see that elements are prefectly shaped.
    Please find attached the modified model.
    Best regards,
    Gunter
  • Gunter
    Gunter
    Altair Employee
  • sbhbajra
    Dear Sir
    Thank you very much for your reply.
Welcome!
Welcome!
