Using SDI with Embed
User: "Markus_20691"
Altair Community Member
Updated by Markus_20691
Dear Altair Embed Support Team,
I have a more complicated question:
My goal is to interface an ADC (ADS8555EVM-PDK from TI) by reading the results with the TI-Launchpad-F28069M. Currently I am achieving this by using a finite state machine which is reading the bits in parallel-mode. I am currently reading 3 channels (one after another) and I get a data rate of around 5kHz  which is not so fast.
The ADC has a SDI output.
So I want to know, if Embed provides a programed solution for interfacing of
the ADC over the SDI-port. I ask because than I would read the data over the SDI-port which is hopefully a lot faster.
I attached the documentation of the ADC.
Again thank you for your help.
Kind regards
Markus
