Hi all,
I am trying to transform a PSD into a time-history. I am using the method described in the E-book of signal processing under Compose but I am facing two errors in the script, namely I cannot display the time signal and the inverse calculation to recalculate the DSP with the time signal does not work with pwelch command
I suppose that this is due to the fact that the vector of the time signal contains ascii characters (NaN + NaNi) but I cannot find the solution.
I am attaching the script.
Thank you in advance for your help.
Arnaud
