Hi all,
I want to use the result of the next formula:
As the imput of a Sawtooth block, specifically the period parameter:
It's possible?
Hi @Carlos Fondevila,
One way of designing this would be with the help of the Diagram variables:
In the Diagram window, create the variables for c1, c2, and p. Then they can be used within the constant block and sawtooth block as needed:
Hope this helps!
Adam Reid
Thanks Adam!
