🎉Community Raffle - Win $25
Join and Win
Invalid ResultMath expression at Hyperview
User: "Iban"
Altair Community Member
I have one problem when creating a new expression throught expression builder at HyperView.
I have a component that is heated and bent at the same time. I have successfully created an expression that returns a stress value based on the temperature of a component. This is the working expression:
7.00140E-12R1.S29^5-2.33338E-08R1.S29^4+3.01977E-05R1.S29^3-1.86514E-02R1.S29^2+5.27671E+00*R1.S29^1-4.79263E+02
Now when I try to subtract the vonMises stress from the above expression, Hyperview gives me an error. This is the expression that doesn't work:
(7.00140E-12R1.S29^5-2.33338E-08R1.S29^4+3.01977E-05R1.S29^3-1.86514E-02R1.S29^2+5.27671E+00*R1.S29^1-4.79263E+02)-(R2.T2.C11.L3)
And this is the warning:
Invalid ResultMath expression (Binding mismatch: lhs binding is not mismatched with rhs binding for Substract
1 - 4 of 41
    Hello @Iban ,
    your expression is curious to me:
    7.00140E-12R1.S29
    Shouldn't there be something (a multiplication, …) between 7.00140E-12 and R1.S29 (same for the other terms)?
    What does your expression look like if you uncheck the option "Display Alias":
    Regards,
    Michael
    User: "Iban"
    OP
    Updated by Iban
    Hello Michael,
    You are right, this is the correct expression:
    7.00140E-12*R1.S29^5-2.33338E-08*R1.S29^4+3.01977E-05*R1.S29^3-1.86514E-02*R1.S29^2+5.27671*R1.S29-479.263
    And when I uncheck "Display alias":
    (((((("0.000000000007"*("model.Temperature"^"5"))-("0.000000023334"*("model.Temperature"^"4")))+("0.0000301977"*("model.Temperature"^"3")))-("0.0186514"*("model.Temperature"^"2")))+("5.27671"*"model.Temperature"))-"479.263")
    And when I try to substract th von Mises stress it look like this
    (((((((("0.000000000007"*("model.Temperature"^"5"))-("0.000000023334"*("model.Temperature"^"4")))+("0.0000301977"*("model.Temperature"^"3")))-("0.0186514"*("model.Temperature"^"2")))+("5.27671"*"model.Temperature"))-"479.263")-"result.Stress.vonMises")
    Thanks in advance
    User: "Michael Herve"
    Altair Employee
    Accepted Answer
    Hello again @Iban ,
    is temperature a nodal, or an elemental result? The error message you received (binding mismatch) would make me think it is a nodal results (so a result binded to nodes), whereas the stress is binded to elements.
    If I'm correct, you neeed first to load your results with ResultMath template = Advanced, the to change binding mode from one of the contours, so either use BCNodeToElem with temperature, or to use BCElemToNode with Stress
    Here's an example of how to use such operators tin HyperView:
    Regards,
    Michael
    User: "Iban"
    OP
    Updated by Iban
    Hi Michael,
    The temperature is nodal result, that was the binding mistmatch.
    Now, using BCElemToNode with the stress at the expression it works correctly.
    Thank you very much
