Is there a software version requirement for coupling between edem and hyperworks?
karl_chao1226
karl_chao1226 Altair Community Member
Hi,Altair team
I want to inquiry about the versions requirement between edem and the hyperworks during coupling.Could I use a the advanced version of hyperworks coupled with a previous version of edem? (e.g edem 2022.0 with the hyperworks 2023)
Grateful for your help,
Chao
Welcome!
Answers
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi Chao,
    What kind of application were you looking to simulate? Is his coupling EDEM with HyperWorks CFD or other?
    Regards
    Stephen
  • karl_chao1226
    Hi Stephen,
    I want the EDEM coupling with the HyperWorks CFD.
    Best regards
    Chao
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi Chao,
    In general I would recommend making sure both HyperWorks CFD and EDEM are the same version, there are some updates which apply to both and may cause some issues if you mix.
    Regards
    Stephen
  • karl_chao1226
    hi Stephen,
    Thanks for your kindness advice! Have a nice day!
    Chao
  • karl_chao1226
    Hi Stephen,
    When i start performing the case of the windshifter_undirectional,coupling between the EDEM and hyperworks CFD,i can't find the EDEM model with the windshifter_undirectional.dem. Could i have the model of these EDEM coupling cases if you're connvient? Thanks in advance for your help.
    Chao
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi It should have generated the files in Step 5 of the tutorial, it's probably best to check why it didn't create the files as that is a part of the tutorial. They should be generated in the problem directory.
    Or you could try the 6101 tutorial which also uses the same geoemtry but generates the files in a differnet way (step 6)
    Site faviconACU-T: 6101 Particle Separation in a Windshifter using AcuSolve - EDEM Unidirectional Coupling
    Regards
    Stephen
Welcome!
Welcome!
