1 - 1 of
11
Hi,
You need to ensure the different particles have a different Charge value which you set in the Factory.
If one particle has +ve charge and one -ve charge they will be attracted to each other, if they both have the same +ve or -ve then they will be repulsed.
Regards
Stephen
Hi,
https://help.altair.com/edem/topics/creator_tree_physics/the_electrostatics_model_r.htm
Regards
Stephen
