How can I remove this error in wire meshing? [FEKO 2023.1 Version]
Hi , My probe radius is 5mm in my model, I tried using Fine /standard meshing option in my model, but for both cases, there is the same error msg "The ratio of probe radius to length is very large" . My model is attached here. Kindly check the model and
help me to fix this error message in my simulation. Thanks in advance!
Best Answer
If you'd like to consider the feeder wire's radius, you need to replace the wire with a 3D geometry (cylinder).
Please refer to the following steps.
- Draw a cylinder. ← after deleting the wire feeder.
- Region medium → Free space
- Split the cylinder and union.
- Apply the edge port. → Voltage source.
Best regards,
Jaehoon
1
Answers
Hello,
Feko's wire segment mesh is based on the thin wire approximation. Therefore, the wire segment's radius should be smaller than the segment's length (Maybe 5~10 times smaller).
Please change the wire segment radius (5 → 0.001) in Modify mesh setting as shown below.
Best regards,
Jaehoon
1 -
@Torben Voigt sir can you help fixing this error? my probe radius should be 2.5mm
0 -
Best regards,
Jaehoon
1 -
@Jaehoon sir thanks, let me see how this cylinder effects my s11 .
0
