Generate h3d file from EDEM results
Hi all,
I want to convert the EDEM simulation results into animation H3D file for post-processing in HyperView, as it is described in the tutorial MotionSolve/EDEM co-simulation:
. However, I do not see the function 'Generate H3D from EDEM results', which should be available in MotionView, as described here . If I use the search bar to search for this function in MotionView it is also not working. I use the version 2024.1 of both EDEM and HyperMesh. Could anyone help me out with this, why is this function not available anymore in the software?Kind regards,
Pim
