how to plot contact chain in EDEM
QinHe_321
QinHe_321 Altair Community Member
Welcome!
Best Answers
  • PrasadAvilala
    PrasadAvilala
    Altair Employee
    Answer ✓
    Hi QinHe,
    Can you please go through the below forum link which helps to address your query
    Force chains — Altair Community
    Thanks,
    Prasad A
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Hi, just to note if you go to the EDEM Analyst. Select Particles and de-select 'Display All' then choose Apply All (you may have to scroll down)
    Then go to Contacts and choose All-All or change to Particle-Particle/Particle-Geometry as required and then select 'Display Contacts'. You can colour these by your chosen measure.
    Regards
    Stephen
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Hi, you can use the Contact Opacity to make it transparant:
    Or use a clipping plane/slice to cut the model:
    Regards
    Stephen
Answers
  • PrasadAvilala
    PrasadAvilala
    Altair Employee
    Answer ✓
    Hi QinHe,
    Thanks,
    Prasad A
  • QinHe_321
    https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0121981
    page not found in this link
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Regards
    Stephen
  • QinHe_321
    Yes, that shows a section, I was hoping to make it half transparent to see the whole.
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Regards
    Stephen
Welcome!
Welcome!
