Many elements in the standard PSIM library can be used for code generation but not all!. In order to differentiate the elements in the standard library that can be used for code generation from the ones that can not, underOptions >> Settings >> Advanced, if the option box "Show image next to elements that can be used for code generation" is checked, a small "CG" image will appear next to these elements that can be used for code generation.
Upon inspecting the provided image, it is evident that the "Turn-on Time Delay (logic)" block is not supported for code generation. On the other hand, the "Unit Delay" block is compatible:
Of course, all the elements under the menu Elements >> Event Control and Elements >> SimCoder are available for code generation along with the standard library ones. You can follow more details on this by navigating to the Simcoder User Manual.pdf:
Dear User,
Many elements in the standard PSIM library can be used for code generation but not all!. In order to differentiate the elements in the standard library that can be used for code generation from the ones that can not, under Options >> Settings >> Advanced, if the option box "Show image next to elements that can be used for code generation" is checked, a small "CG" image will appear next to these elements that can be used for code generation.
