Inquiry Regarding EDEM and Fluent Coupling
Wissenschaft
Wissenschaft Altair Community Member
CAUTION: This email originated from outside the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
Hello
I'm currently exploring the possibility of coupling EDEM with Fluent. However, I have encountered an issue regarding the need for a compiler to transfer data to the .jou file from the tutorial. Or do I missunderstand the Tutorial?
Could anyone kindly provide me some guidance or assistance on how to proceed with this?
Thanks in advance
Best Answer
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Hi, the EDEM-Fluent coupling compiler is currently available on a case by case basis. I will send you a separate mail regarding access.
    Regards
    Stephen
Answers
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Answer ✓
    Regards
    Stephen
  • Wissenschaft
    Hi Stephen,
    thank you for the EDEM-Fluent coupling compiler. It is working now.
    Best regards,
    Wi
Welcome!
Welcome!
