🎉Community Raffle - Win $25
Join and Win
How to connect to SQL Server in Altair SLC on MacOS
User: "Vinay_C"
Altair Community Member
I am trying to connect to SQL Server on MacOS. I am getting this error:
ERROR: Could not load SQLSERVR engine or one of its dependent libraries. Please ensure that youhave installed the relevant client libraries for connecting to SQLSERVR and that they canbe located by Altair SLC before trying to connect.
I can access the database from VSCODE and from the terminal. ODBC is configured, I can locate the driver path through odbcinst -j command. I tried changing /etc/odbc.ini as recommended in one of the community blogs but it didn't help.
I checked Proc SETINIT and confirmed that SQLSERVER is an available option.
Product: Altair Analytics Workbench Version: 5.23.7.0.520-GA-release
Any help will be greatly appreciated.
PROC SQL;
CONNECT TO sqlservr(
    server='some-server.database.windows.net'
    port=1433
driver='ODBC Driver 18 for SQL Server'
database='mydb'
    user='myuser'
password='mypassword'.
encrypt='yes'
SELECT * FROM CONNECTION TO sqlservr(
  SELECT 1 AS TestConnection
DISCONNECT FROM sqlservr;
QUIT;
