Modelling a nodal spring in Altair hyper works (Optistruct)
Mohamed_ABDO
Mohamed_ABDO Altair Community Member
Hello,
I am attempting to model a concrete slab that rests on soil, and I wish to represent the soil using spring elements. I would like to know which spring element type I should use to define the stiffness in the x, y, and z directions (Kx, Ky, and Kz).
I have tried using CBUSH and CBUSH1D elements, but I have found that they only allow me to define axial stiffness, which results in differences compared to the model where the soil is represented using solid elements.
Could you please advise on the appropriate spring element type that would enable me to define stiffness in all three directions (Kx, Ky, Kz) accurately?
Thank you for your assistance.
Best regards.
Answers
  • Rajashri_Saha
    Rajashri_Saha
    Altair Employee
    Hi,
    For defining stiffness in different directions, you should use CBUSH element with PBUSH property.
    In K1 to K6 fields , you can define stiffness values in directions 1 through 6.
    Refer the below link to know more on PBUSH property.
    Site faviconPBUSH
    Thanks
    Rajashri
Welcome!
Welcome!
