How to connect to SQL Server in Altair SLC on MacOS
I am trying to connect to SQL Server on MacOS. I am getting this error:
ERROR: Could not load SQLSERVR engine or one of its dependent libraries. Please ensure that youhave installed the relevant client libraries for connecting to SQLSERVR and that they canbe located by Altair SLC before trying to connect.
I can access the database from VSCODE and from the terminal. ODBC is configured, I can locate the driver path through odbcinst -j command. I tried changing /etc/odbc.ini as recommended in one of the community blogs but it didn't help.
I checked Proc SETINIT and confirmed that SQLSERVER is an available option.
Product: Altair Analytics Workbench Version: 5.23.7.0.520-GA-release
Any help will be greatly appreciated.
PROC SQL;
CONNECT TO sqlservr(
server='some-server.database.windows.net'
port=1433
driver='ODBC Driver 18 for SQL Server'
database='mydb'
user='myuser'
password='mypassword'.
encrypt='yes'
SELECT * FROM CONNECTION TO sqlservr(
SELECT 1 AS TestConnection
DISCONNECT FROM sqlservr;
QUIT;
I created the script altairslcenv.sh in the folder /Applications/altairslc.app and sourced it in ~/.zshrc but the error remains the same. Please see the content of altairslcenv.sh, odbcinst.ini, and odbc.ini
Content of altairslcenv.sh -
#!/bin/bash
# Set the path to the odbc.ini file
export ODBCINI=/opt/homebrew/etc/odbc.ini
# Set the path to the directory containing odbcinst.ini
export ODBCSYSINI=/opt/homebrew/etc
# Set the path to find UnixODBC and SQL Server libraries
export DYLD_LIBRARY_PATH=/opt/homebrew/lib:$DYLD_LIBRARY_PATH
Content of odbcinst.ini -
[ODBC Driver 18 for SQL Server]
Description=Microsoft ODBC Driver 18 for SQL Server
Driver=/opt/homebrew/lib/libmsodbcsql.18.dylib
UsageCount=1
Is there a specific content that must go in odbc.ini? The current content is
[SQL Server]
Driver=ODBC Driver 18 for SQL Server
Server=some-server.database.windows.net
Port=1433
Database=some-database
Encrypt=yes
TrustServerCertificate=no
When checking a unixODBC configuration you should use:
odbcinst -j # this command reports what .ini files you are actually using
isql -v dsn user passwd # this command demonstrates that you can connect to the database okay
And within the Altair Analytics Workbench you can check that your environment variable settings have been correctly set up by executing sas language code like this:
%put DYLD_LIBRARY_PATH is "%sysget(DYLD_LIBRARY_PATH)";
Nico
isql -v dsn user passwd # This works
WARNING: The argument DYLD_LIBRARY_PATH to macro function SYSGET does not name an existing environment variable
DYLD_LIBRARY_PATH is ""
It appears that AltairSLCenv.sh is not getting initialized or AltairSLC is not reading these environment variable. I have stored is file in /Applications/AltairSLC.app. Should it be in the Contents folder under /AltairSLC.app?
Then I guess the issue is with the odbc.ini or odbcinst.ini files and the way altairslc reads it. Is there a specific structure or content to these files that altair understands. The environment variables are getting set properly.
213 %put DYLD_LIBRARY_PATH is "%sysget(DYLD_LIBRARY_PATH)";
DYLD_LIBRARY_PATH is "/opt/homebrew/lib"
214 %put ODBCSYSINI is "%sysget(ODBCSYSINI)";
ODBCSYSINI is "/opt/homebrew/etc"
215 %put ODBCINI is "%sysget(ODBCINI)";
ODBCINI is "/opt/homebrew/etc/odbc.ini"
If you are still getting the error message "Could not load SQLSERVR engine or one of its dependent libraries" this really does seem to mean that SLC didn't find the expected shared libraries on DYLD_LIBRARY_PATH. Maybe set the DYLD_LIBRARY_PATH so that both the unixODBC shared libraries and the SQLServer libraries are all present on that path?
Hi Vinay,
You could try using version 17 instead of version 18 of the driver perhaps? In case latest version happens to have some new incompatibility.
Unfortunately I don't have time to reinstall on my Mac at the present time but I'll aim to try it again and report back to you when I can.
Nico
The error message…
…essentially means that SLC didn't find the expected shared libraries on DYLD_LIBRARY_PATH.
There are many places you could set/modify DYLD_LIBRARY_PATH but a good recommendation for SLC would be: You can create a script called
/Applications/altairslc.app/altairslcenv.sh
containing the necessary command for updating that environment variables. You might want to set ODBCINI and ODBCSYSINI as well as DYLD_LIBRARY_PATH in that script.n.b. SLC needs to find the unixODBC libraries on DYLD_LIBRARY_PATH as well as the SQLServer ODBC libraries that ought to be found via the odbc .ini files.
