Error when executing python file generated from .psimsch file
User: "Mario_Steiner"
Altair Community Member
I generated a .py file using the "Save as Python Code" function in the "File" tab.
When i want to run this .py file then, i recieve the error:
from .Psim_Class import PSIM
ImportError: bad magic number in 'psimapipy.Psim_Class': b'U\r\r\n'
I executed the Altair_PSIM_2024.1\Python\Source\dist\psimapipy-2024.0-py3-none-any.whl and the .bat files in Altair_PSIM_2024.1\Python\Source\
Did i mess up the installation?
1 - 6 of 61
    User: "VSiddhartha"
    Altair Employee
    Hi,
    May I know which version of python you are using?
    Please try this tutorial
    Thank you,
    Vishwanatha Siddhartha
    OP
    I use version 3.11.5
    User: "VSiddhartha"
    Altair Employee
    Hi,
    It should be 3.8 or above.
    Requirements and procedure available in tutorial.
    Please go through once.
    Thank you,
    OP
    3.11 is above 3.8?!?
    My problem is nor understanding the python code but the correct installation of psimapipy
    User: "VSiddhartha"
    Altair Employee
    Hey, I am sorry. You are using correct version.
    Just in case something is wrong with installation, please navigate to Options » Set Path… » Install psimapipy and browse to your python.exe.
