Error when executing python file generated from .psimsch file
Mario_Steiner
Mario_Steiner Altair Community Member
I generated a .py file using the "Save as Python Code" function in the "File" tab.
When i want to run this .py file then, i recieve the error:
from .Psim_Class import PSIM
ImportError: bad magic number in 'psimapipy.Psim_Class': b'U\r\r\n'
I executed the Altair_PSIM_2024.1\Python\Source\dist\psimapipy-2024.0-py3-none-any.whl and the .bat files in Altair_PSIM_2024.1\Python\Source\
Did i mess up the installation?
  • VSiddhartha
    VSiddhartha
    May I know which version of python you are using?
    Please try this tutorial
    Thank you,
    Vishwanatha Siddhartha
  • Mario_Steiner
    I use version 3.11.5
  • VSiddhartha
    VSiddhartha
    It should be 3.8 or above.
    Requirements and procedure available in tutorial.
    Please go through once.
    Thank you,
  • Mario_Steiner
    3.11 is above 3.8?!?
    My problem is nor understanding the python code but the correct installation of psimapipy
  • VSiddhartha
    VSiddhartha
    Hey, I am sorry. You are using correct version.
  • Just in case something is wrong with installation, please navigate to Options » Set Path… » Install psimapipy and browse to your python.exe.
