I need some help to solve this warning PYTHON ANALYSIS PATH
I tried to perform some simulations with edemCAL, and then the next warning appeared when I pressed start simulating.
I've already installed Python version 3.8.10 and added the path to the environmental variable.
the warning still appears even though I've already added the path to the environmental variable.
Please help me to solve this problem with edemCAL
1 - 1 of
11
Hi, You could try running the 'generate files for distributed simulation' option which allows you to run the EDEM simulations via batch and you can manually specify the python executable to run there.
EDEMCal was originally created prior to EDEM-Hyperstudy connection, you can use Hyperstudy for the same functionality:
