Hi, I have this error when running my analysis.
*** ERROR # 4966 ***
Minimum time increment reached,
analysis aborted.
I tried to adjust the minimum time increment from 5e+06 to 5e+07, but the analysis took the entire night to run only 0.5%. And in the *nl.out flie, it shows the analysis failed with "element distortion". Does anyone know how to solve this problem? Appreciate any help and thank you!
