🎉Community Raffle - Win $25
Join and Win
Is there a Tcl command in Hypermesh to query the material orientation vector of an element?
I was wondering if there's a simple Tcl command to get the coordinates of the material orientation vector of an element, just like hm_getelementnormal
*reviewmaterialorientation actually reads this vector before plotting it but I'm struggling to access its coordinates.
Thanks in advance!
1 - 7 of 71
    Hello @Deleus ,
    this might not be as straightforward to query it, and as a starter that will depend on the solver interface you are working with. May I ask you which solver you are using?
    Best Regards,
    Michael
    Hello Michael,
    I'm using Optistruct at the moment.
    Hello @Deleus ,
    the material orientation for OptiStruct should be accessed from the elements directly, as you should define the orientation in CTETRA element, through the CID parameter.
    Best Regards,
    Michael
    I know exactly how to access this info from the HM interface; what I'm looking for is a .tcl command similar to hm_getelementnormal and use it in a script…
    Hello again,
    as the material orientation is based on element, you need to query the orientation for each element. I assume that for elements beloging to the same part, you should get the same orientation.
    So that should lead you to a code such as below:
    *createmark elems 1 "by aterial" $MatId
    set CID [lsort -unique [hm_getvalue elems mark=1 dataname=system]]
    set orientation [hm_getvalue system id=CID dataname=xaxis]
    Also, may I ask you for a larger picture of what you try to achieve? Meaning, what do you do with this material orientation once you get it? This may help me to propose you a better strategy
    Best Regards,
    Michael
    DeleusUser: "Deleus"
    Altair Community Member
    OP
    Updated by Deleus
    In Optistruct, I solved the issue by querying the attribute THETA.
    From what I understand, there is no native Material Orientation Vector, instead Optistruct operates a rotation of THETA degrees of the vector G1-G2 around the element normal.
    For example, to query the attribute THETA for all displayed elements and store it in a list:
    *createmark elems 1 "displayed"
    set list [hm_getvalue elems mark=1 dataname=THETA]
    Hello @Deleus ,
    you are right, Theta is another way to query element orientation, depending about how the orientation was defined.
    Best Regards,
    Michael
