how to import abaqus inp model into motionview with all force and constrains?
User: "QinHe_321"
Altair Community Member
Is it possible through motionview itself, hypermesh or other softwares?
I need to transfer a complex model from other group's work, so it is necessary.
1 - 3 of 31
    User: "GTT Adam"
    Altair Employee
    Hi @QinHe_321,
    To import a flexible body file into MotionView, you can import an .INP file by creating a body, setting it to "Flex Body", and then choosing the .INP file, as outlined in the following link:
    Using H3D Flexbodies in MotionView
    Hope this helps!
    Adam Reid
    User: "QinHe_321"
    OP
    Error Evaluating happens when I import inp file as flex body.
    Qin
    User: "GTT Adam"
    Altair Employee
    Accepted Answer
    Hi @QinHe_321,
    Do you have access to an older version of MotionView? The documentation reflects the 2022.3 interface, so you may need to open / install that version to take advantage of this older feature.
    In 2022.3, you can change the Solver Mode to Abaqus:
    If I now create a body, you can see it shows inputs for the .INP
    Hope this helps!
    Adam Reid
