Is it possible through motionview itself, hypermesh or other softwares?
I need to transfer a complex model from other group's work, so it is necessary.
Hi @QinHe_321,
Do you have access to an older version of MotionView? The documentation reflects the 2022.3 interface, so you may need to open / install that version to take advantage of this older feature.
In 2022.3, you can change the Solver Mode to Abaqus:
If I now create a body, you can see it shows inputs for the .INP
Hope this helps!
Adam Reid
To import a flexible body file into MotionView, you can import an .INP file by creating a body, setting it to "Flex Body", and then choosing the .INP file, as outlined in the following link:
Using H3D Flexbodies in MotionView
Error Evaluating happens when I import inp file as flex body.
Qin
