user defined EDEM contact model error
1 - 7 of
71
I changed the version to 3 1 0, then this error do not happens.
EXPORT_MACRO int GETCMINTERFACEVERSION()
static const int INTERFACE_VERSION_MAJOR = 0x03;
static const int INTERFACE_VERSION_MINOR = 0x01;
static const int INTERFACE_VERSION_PATCH = 0x00;
return (INTERFACE_VERSION_MAJOR << 16 |
INTERFACE_VERSION_MINOR << 8 |
INTERFACE_VERSION_PATCH);
Hi,
It looks like a warning rather than an error, potentially eCalculateForce is not always returning success or the F1 variable could be returning 'not a number'. You may need to debug this to check what is happening.
I would recommend using the latest version of the API, I'm unsure which version of the API you are using but the variable cohesion model was recently updated to the latest version supported in EDEM 2024.1:
And we have a guide on how to update API versions:
Regards
Stephen
