How do I activate Optistruct?
Andile
Andile Altair Community Member
I have downloaded HyperWorks, both the 2024.1 versions and the 2022.3. However , the 2024.1 version of HyperWorks does not work on my PC (I will submit a separate query regarding this) so I use the 2022.3 version. I am trying to use the Alatir Computer Control module to run a model on Optistruct but it optruct does not appear to be a relevant module. I have download Optistruct, I'm pretty sure it is the latest version.
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    Sorry about the basic question: how did you install the products?
    The suggested approach is to download all the required installers and install using the main installer, that will properly install the others.
    If you did that, I'd check if the checksum of your mechanical solvers installer is correct.
  • Andile
    Hi, I am pretty sure that is how I did it. However when i downleaded hyperWorks/HyperMesh there was no optisruct app in the folder so i downloaded it separately. Could the issue be that I am attempting to use hwSolvers2024.1_win64 on 2022.3 version of Hypermesh?
Welcome!
Welcome!
