Floating point exception in EDEM-fluent coupling.
fyw
fyw Altair Community Member
I tried to simulate flow impingement on particle bed. I use quiet big mesh as the particles is large. The flow simulation without particle runs properly.
But when I run EDEM-Fluent coupling simulation, the residuals increase in the beginning and floating point exception error occurs within 100 iterations.
The error message is
" Reversed flow on 770 faces of pressure-outlet 9.
Stabilizing mp-x-momentum to enhance linear solver robustness.
Stabilizing mp-x-momentum using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: pressure correction
Error at host: floating point exception
Error: floating point exception
Error Object: #f"
I tried these ways, but they seems have no effect.
  1. reduce the fluent timestep
  2. change pressure cycle type to flexible.
  3. increase the max iterations per time step.
I guess the error comes from volume fraction caculation, but I have no clue how to solve it. Below is the volume fraction and fluid velocity, pressure.
  1. volume fraction
2. velocity
3. pressure
2024.11.16
fang yanwei
Answers
Welcome!
Welcome!
