Help regarding Meshing in hypermesh
Dear Admin,
I would like to ask your kind advice regarding meshing. I have a 3d voxel meshed file. The voxels are defined as solid sections. Now, all I want is to remove the voxels which are not sharing at least a common face. So, if any voxel that is not sharing a face with another voxel but sharing an edge or a corner, needs to be deleted. I want this to be done for all the existing voxel elements with one single procedure and not one by one. How can I do this.
Thanks in advance.
