Error 1083: Part Definition
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I created an composite part with P11_SH_SANDW but when i can for check it showed some errors because a material was not assigned to the property. what kind of material should i assign and what values should i give for the same. I have attached the screenshot of the error and part defined.
1 - 9 of 91
    Altair Employee
    OP
    Hi,
    You can use /MAT/LAW 25 for P11 type property for example. Please refer to RADIOSS help for sample material details for LAW25
    Altair Employee
    OP
    @Prakash Pagadala Im getting a error for RBODY saying Error id 179, ** Error in part definition. What material and properties should I define for Rigid connections (RBODY).
    I solved it by checking the Rbody/Adams Box.
    Now I have an error id 760. Error trapped: Report to listing file
    Altair Employee
    OP
    Hi @tintumat
    Can you check whether rigid bodies has PART card image?
    If yes, can you remove PART card image for rigids and try again?
    Altair Employee
    OP
    @Prakash Pagadala I have a 3D component, which is assigned with P14 solid and elastic material. when running without Card image as part is shows Error 760, Error trapped. While assigning Card image as Part it shows error id 495, error in shell definition.
    Altair Employee
    OP
    Hi @tintumat
    Looks like a modeling/pre-processing error. Do you have any shell elements?
    If yes, delete the same if they are not necessary and make sure you have the PART card image for the solid component.
    Could you please share the model file if the above didn't help?
    Please use the file transfer link in my signature to share the model file
    Altair Employee
    OP
    Hi @tintumat
    I have shared the file
    Altair Employee
    OP
    Hi @tintumat
    I have shared the modified files with you. Please run the same and check the results.
    Altair Employee
    OP
    @Prakash PagadalaHow did you fix the issues with the solid part?
    the run terminated with warnings.
    1.  warning 343: initial penetrations in interface.
    2. Warning 312: Incompatible Kinematic conditions in model
    Altair Employee
    OP
    Hi,
    Maybe you didn't define the Run time. Can you check the same?
    I am able to run the file at my end.
