3D mesh with 2D anchors
Hello everyone!
I have a problem which I can't solve for a few days already, hope on your help.
I need to get :
3D mesh of cube with 2 components and identical (or close to) nodes on the opposite surfaces of the cube.
So far I have:
2 solids connected to each other, 2D mesh of the surfaces (identical to the opposite)
It seems to be easy but it's not, couldn't find similar case on the forum.
Here's the model bellow:
Thank you!
Thank you for your response.
So far I have 2D periodic mesh of the cube (opposite surfaces have the same mesh), I want to keep those elements as anchors.
I tried to assign the mesh to the geometry but unsuccessfuly cause it changes the mesh)
Also I have fibers part, I need to keep blue comp as anchors and connect green part to it (green part can be remeshed).
If I'll connect the green mesh to the blue one, I'll be able to make 3D mesh through TetraMesh tool.
Thank you!
Sure,
I use Geometry->NodeEdit->Associate
For example, here we can see Front Plane View. Meshes on different surfaces are identical that's why from this point of view we see those as one mesh.
After Associate operation, in places of connection of surfaces I have such a displacement:
I tried to use different tolerance but it couldn't help.
I guess the reason of the displacement is that my geometry somehow has micro-defects so it's not equal to the opposite one.
And when I associate the mesh with the geometry, it changes the mesh.
No, no, I don't need to.
I just tried to assign the mesh to the geometry cause it's easier to operate with geometry.
At this moment I'm trying to connect different 2D Meshes together.
One of those meshes shouldn't be changed (anchor).
The problem is I have free edges which I can't fix by equivalence tool cause I can't change blue mesh.
I can fix it manually by 'Replace' tool but it would take too much of time.
So I'm looking for a way to connect those meshes without changing the blue mesh.
Thanks a lot, your idea sounds like a way to solution.
I just haven't worked with remeshing before.
So I replace 3 nodes, and then should I use 'Tetra remesh' tool?
Or is there any other tools for remeshing?
I connect 3 (Replace nodes tool) nodes then remesh elements (Automesh tool).
But it doesn't distribute new nodes as you said.
Am I doing something wrong?
Also I tried Surface deviation tool, it helps to connect the elements but it changes the mesh and add new nodes.
Appreciate your help.
Thank you @tinh your solution worked well!
And thank you @alpha for alternative solution.
I'm sorry just wanted to ask last question.
After I adjusted my 2D mesh properly I had no free edges in my model.
Then I used tetramesh tool to make 3D model out of 2D with regard to anchors.
After that my 3D mesh had some free edges (red lines on a picture below).
Those edges can't be fixed.
Is this some kind of glitch of the program?
@tinh
Thank you very much!
I don't have v2019
Could you show a screenshot?
