🎉Community Raffle - Win $25
Join and Win
Can I know which operators (and the process) were used to solve a problem with the XML?
User: "Hdejesus"
New Altair Community Member
Updated by Jocelyn
When your run a process Rapidminer generates an XML. I wonder if we can use that text or information for some else to be able to run the same process on their end.
I have an older version of Rapidminer (5.3.015) and this method did not work for me - https://community.rapidminer.com/discussion/50470/import-xml-code-to-process
Thanks for your time and help!
