<operator activated="true" class="model_simulator:data_statistics" compatibility="10.3.000" expanded="true" height="82" name="Statistics" width="90" x="246" y="34"/>
Here are some common tasks and operators you might use when working with XML:
Parsing: Reading an XML document and converting it into a data structure that can be manipulated programmatically. This often involves using libraries or built-in functions specific to the programming language you're using.
XPath: A query language for selecting nodes from an XML document. XPath expressions can be used to navigate through the hierarchical structure of an XML document and select specific elements or attributes.
XSLT (eXtensible Stylesheet Language Transformations): A language for transforming XML documents into other formats, such as HTML, or into different XML structures. XSLT uses templates and patterns to specify how the transformation should be performed.
DOM (Document Object Model): A programming interface for accessing and manipulating XML documents as a tree of nodes. With DOM, you can programmatically create, modify, and delete elements and attributes within an XML document.
SAX (Simple API for XML): A stream-oriented approach for processing XML documents. SAX parsers generate events as they encounter elements, allowing you to respond to those events in your code.
XML Schema: A way to define the structure, content, and data types allowed in an XML document. XML Schema documents can be used to validate whether an XML document conforms to a specified structure.
