1 - 2 of
21
I used "Generate Attributes" to get new field concatinating the month and the date fields, then I used Nominal to Date to convert it to Date. But I want the histogram to show bars by months
Hello @FouadKayali,
concatenating the two fields seems enough to use this new attribute on your x-axis. No need to convert it to an actual date.
