Altair RISE
Nominate Yourself Now!
ARIMA - impossible to work with generated forecast from Arima
User: "Moucho84"
New Altair Community Member
Updated by Jocelyn
dear Community,
I did a revenue forecast using the Arima model, before this and to have stationary data, I use the operator logarithm, I obtained the forecast from Arima operator followed by "apply forecast", my next step was to generate an attribute using the function "exp" (exponentiel) however I cannot see the select any attribute except the date ?
I can see that the attribute is appearing in the results under a new column of data combining historical revenue and forecasted revenue under the name "Revenue and forecast" but impossible to select this attribute.
can you help me pleae ?
1 - 6 of 61
    Hi,
    what happens if you just type it in and run it? Might be just a meta data issue.
    BR,
    Martin
    User: "Moucho84"
    OP
    Hi Martin,
    yes I have the result where I can see
    - the revenue for past period (test data)
    - the forcasted revenue in a separate column for the horizons required
    - the sum of original revenue + the forecasted data under a third column named : Revenue and Forecast
    problem is that the data are logarithm, I need to use the operator : generate attribute with « exp » to have the exponential value and the real revenue. However I cannot find this attribute in the process design as if not existing.
    thanks in advance
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    can't you just use Generate Attributes and use exp([Revenue and Forecast]) there?
    BR,
    Martin
    User: "Moucho84"
    OP
    This is what I tried but :
    - generate attribute connected as next step is mot allowing me to select this new attribute in the formula
    - and if I just write the formula as suggested (matching perfectly the name) i have an error message :  potential problem « the attribute Revenue and forecast is unknown »  - I launched  the proces and this is now working ;) thank you !!!
    Altair Employee
    Accepted Answer
    There seems to be some issue with the meta data here. Can you share to process so @David_A and I can check?
    Best,
    Martin
    User: "Moucho84"
    OP
    Just an additional question, to generate the forecast I had to split the population by business and activity using « filter example »
    now I am dupplicating the process by country, activity and obtain results for each tab (having 6 countries and 6 business line and in it 3 activity - i am ending with 6*6*3 = 108 tabs of results)
    Which operator can I use at the end to group all result into 1 tab (combining all country, their busines  and activity with their name) ?
    or shall I explore a kind of loop process, allowing the process to do it activity by activity and country by country ?
