Hi @rey21, sorry for the slow reply. Had you seen the 'Create Association Rules' operator in RapidMiner Studio, along with the inbuilt example? If I understand your problem correctly, there's two approaches you could take:
you could allow the model to try and find the association of male being true along with buying eggs and milk
or you could take a more manual approach and produce rules whilst only taking examples where gender=male in the data pre-processing stage and then re-run with gender=female and compare results
- you could allow the model to try and find the association of male being true along with buying eggs and milk
- or you could take a more manual approach and produce rules whilst only taking examples where gender=male in the data pre-processing stage and then re-run with gender=female and compare results
Hope this helps!
