Robustness metrics
Hello,
Is there any metric provided to assess robustness / stability of a ML module? As far as I understand the ones provided are more related with the functionality.
I understand reliability as the ability to perform the intended function in the presence of abnormal or unknown inputs, related to ‘reliability’.
Any comment is welcome
Thanks in advance
1 - 2 of
21
Hi there,
anything in particular you search for? You could for example use SHAPly and see how much the output changes?
Best,
Martin
Hello,
Thanks for your answer. I have to analyse it but it could work. I am Quality Assurance people and we are searching for metrics provided by the commercial tools to assess the quality of a ML/AI model. In our research, the metrics provided by the mostly used tools in the market, are related to functionality and not to others characteristics mentioned in ISO/IEC standards for AI systems as Robustness, Transparency, User Controllability.
Our first option is always to use a tool to asssess quality than manual.
Thanks for your support, Regards Teresa
