🎉Community Raffle - Win $25
Join and Win
Getting pretension load value.
Dear All,
I wants to get pretension load value along with node details on which load is applied.
Can we get it directly by using tcl\tk code.
@tinh Please suggest if any api avalailable.
Best Regards,
Vikas Kumar
1 - 12 of 121
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Give a node id, find attached load by *findmark
    Then get load value (please check dataname in hm reference help I don't remember)
    @tinh can you help me with dataname.
    I am unable to understand syntax. How to use that.
    Pls give one example here for above problem in free time.
    How we can get card edit value for all material group member using tcl\tk.
    Regards,
    Vikas Kumar
    Hi all,
    I need help regarding getting card edit values as shown in fig 1 by using tcl\tk.
                     Fig 1
    So it will display all information as shown in Fig 2. All i need is, this value in a list or anything.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.bd4e1af02bfa6a9fd67d27d4c329750c.png
        Fig 2
    Another help i require to get 'XRef Entities' as shown in FIg 3 so it will display again a reference like Fig 4. I need to apply again Xref Entities on same. So i need reference list in a variable.
    Reference list is marked by red color. I need to follow this process only.
    @tinh or @Imoto please provide tcl\tk scripts for above cases.
    I am using abaqus profile (standard 3D) in HM..
    Best Regards,
    Vikas Kumar
    tinhUser: "tinh"
    Updated by tinh
    Regards,
    Vikas Kumar
    Dataname for force value is magnitude
    hm_getentityvalue loads $loadid magnitude 0 -byid
    For card editor fields, use attribute name instead of dataname:
    hm_attributelist mats AL name -byname
    Hi all,
    <?xml version="1.0" encoding="UTF-8"?>image.png.01f67b7756f28292bd9d3eda8fa3064c.png
                     Fig 1
        Fig 2
    <?xml version="1.0" encoding="UTF-8"?>image.png.bc9925669c9f8d1a4a2a0b16f4fdb573.png
    Best Regards,
    Vikas Kumar
    @tinh  Suggest for XRef
    tinhUser: "tinh"
    Updated by tinh
    Hi Vikas
    data names and attribute names have unique type
    for data names, search their type in reference help
    for attribute names, get their type by hm_attributetype, hm_attributetypename
    if the type is 'entity' => that data/attrib is an X-ref
    using hm_attributeentity... to retrieve X-ref data
    Hi @tinh,
    I am using this code
    foreach attr [ hm_attributelist mats 'AL' name -byname] {
        set attrValue [ hm_attributevalue mats 'AL' $attr  -byname ];
        set x [hm_getvalue mats id=1 dataname=$attr]
        set y [hm_attributetypename $attr]
        puts 'attribute: $attr attrVal: $attrValue val: $x attributeTypename: $y'
    Marked line always returns string, integer but not entity at all.
    I am using abaqus profile.
    For particularly x-ref i am not getting any idea.
    Output:-
    attribute: ABAQUS_MATERIAL attrVal: 0 val: 0 attributeTypename: integer
    attribute: Num_Comments attrVal: 3 val: 3 attributeTypename: integer
    attribute: Comments attrVal: 3 val: ===================================== {       AL} ===================================== attributeTypename: arrayofstring
    attribute: CommentEnumField attrVal: 1 val: 1 attributeTypename: integer
    attribute: UseElasticCard attrVal: 1 val: 1 attributeTypename: integer
    attribute: ElasticTypeEnumField attrVal: 1 val: 1 attributeTypename: integer
    attribute: ELASTICDATACARDS attrVal: 1 val: 1 attributeTypename: integer
    attribute: Young attrVal: 1 val: 70610.4 attributeTypename: arrayofreal
    attribute: Poiss attrVal: 1 val: 0.33 attributeTypename: arrayofreal
    attribute: TempE1 attrVal: 1 val: 0 attributeTypename: arrayofreal
    attribute: Elastic_Num_Comments attrVal: 1 val: 1 attributeTypename: integer
    attribute: Elastic_Comments attrVal: 1 val: -------------------------- attributeTypename: arrayofstring
    attribute: UseExpansionCard attrVal: 1 val: 1 attributeTypename: integer
    attribute: Thetanot attrVal: 20 val: 20 attributeTypename: real
    attribute: Expansion_UserEnumField attrVal: 3 val: 3 attributeTypename: integer
    attribute: ExpansionTypeEnumField attrVal: 1 val: 1 attributeTypename: integer
    attribute: Expansion_OptionalEnumField attrVal: 1 val: 1 attributeTypename: integer
    attribute: EXPANSIONDATACARDS attrVal: 17 val: 17 attributeTypename: integer
    attribute: Alpha attrVal: 17 val: 2.17e-005 2.2e-005 2.23e-005 2.27e-005 2.31e-005 2.33e-005 2.36e-005 2.38e-005 2.4e-005 2.42e-005 2.44e-005 2.46e-005 2.48e-005 2.5e-005 2.52e-005 2.54e-005 2.56e-005 attributeTypename: arrayofreal
    attribute: TempAlpha attrVal: 17 val: 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 300 320 attributeTypename: arrayofreal
    attribute: Exp_DependExist attrVal: 0 val: 0 attributeTypename: integer
    attribute: Exp_Depend attrVal: 0 val: 0 attributeTypename: integer
    attribute: Expansion_Num_Comments attrVal: 1 val: 1 attributeTypename: integer
    attribute: Expansion_Comments attrVal: 1 val: -------------------------- attributeTypename: arrayofstring
    attribute: UseConductivityCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseSpecificHeatCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseDensityCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseDampingCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseDielectricCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: Elastic_Depend_Exist attrVal: 0 val: 0 attributeTypename: integer
    attribute: Elastic_Moduli_Exist attrVal: 0 val: 0 attributeTypename: integer
    attribute: FailStress attrVal: 0 val: 0 attributeTypename: integer
    attribute: FailStrain attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseHyperelasticCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseHypoelasticCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseHyperfoamCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: MullinsEffect attrVal: 0 val: 0 attributeTypename: integer
    attribute: UsePiezoelectricCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseViscoelasticCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: CAST_IRON_PLASTICITY attrVal: 0 val: 0 attributeTypename: integer
    attribute: UsePlasticCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UsePotentialCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseCrushableFoamCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseCrushableFoamHardCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseRateDependentMatCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseCreepCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseAcousticCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: User_Output_Variable attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseUserMaterialCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: UseDepVarCard attrVal: 0 val: 0 attributeTypename: integer
    attribute: DEFORMATION_PLASTICITY attrVal: 0 val: 0 attributeTypename: integer
    attribute: MatDamageInitiation attrVal: 0 val: 0 attributeTypename: integer
    attribute: Mat_UnsupportedCards attrVal: 0 val: 0 attributeTypename: integer
    Thanks,
    Vikas Kumar
    tinhUser: "tinh"
    Updated by tinh
    Hi
    Which attribute is entity?
    Hi @tinh
    Here not even single attribute type name is coming as entity.
    But i want this details as mentioned before also (Refer Below image).
    Data marked with red rectangle i needed.
    Manual process i have shown in image.
    Thanks
    tinhUser: "tinh"
    Updated by tinh
    Try
    *createmark props 1 'by material name' AL
    You get 2 props, easily get their names and ids and types
    Hi @tinh
    In this case it is working. Because here we know that both is a property entity.
    But in case of any other entity attached with this material in that case we need to find out.
    Can we find out all attached entity along with this material name in one shot.
    Thanks for your help.
    tinhUser: "tinh"
    Updated by tinh
    you can make a loop through all hm entities and check if severals attach to that material. it is a simple task.
