1 - 3 of
31
Hi Roshan,
If you use SimLab 14.2 or later, you can create custom windows using Python and Tkinter.
It is also possible to create your own buttons on the custom Ribbon with Python and XML in SimLab 2017.2.1 or a bit earlier ones. Sorry I'm not exactly sure of the version.
Regards,
Hi ,
Can you share some example files related to ( buttons on the custom Ribbon with Python and XML in SimLab )
Thank you
Chinna Reddy
Hi Roshan,
Regards,
